<?session_start();require 'include/config.php';if(isset($_SESSION['access_token'])){ if($_SESSION['friend_link_id']!=""){ $num = mysql_num_rows(mysql_query("SELECT id FROM tb_ads_views WHERE user = '".$user_row['id']."' and ad_id = '".$_SESSION['friend_link_id']."' and ad_type = 'friend'")); if($num == 0){ $num_2 = mysql_num_rows(mysql_query("SELECT id FROM tb_ads WHERE balans >= for_one and user != '".$user_row['id']."' and type = 'friend' and link_id = '".$_SESSION['friend_link_id']."'")); if($num_2>0){ $row = mysql_fetch_array(mysql_query("SELECT * FROM tb_ads WHERE balans >= for_one and user != '".$user_row['id']."' and type = 'friend' and link_id = '".$_SESSION['friend_link_id']."'")); $req = file_get_contents("https://api.vk.com/method/friends.areFriends?access_token=".$_SESSION['access_token']."&uids=".$row['link_id']); $data = json_decode($req, true); if($data["response"][0]["friend_status"]!=0){ mysql_query("UPDATE tb_ads SET balans = balans - '".$row['for_one']."' WHERE id = '".$row['id']."'"); mysql_query("UPDATE tb_members SET likes = likes + '".$row['for_one']."' WHERE id = '".$user_row['id']."'"); mysql_query("INSERT INTO tb_ads_views (user,ad_id,ad_type) VALUES ('".$user_row['id']."','".$row['link_id']."','friend')"); $_SESSION['friend_link_id']=""; ?> $(".info").empty().append("<?=$user_row["likes"]+$row["for_one"];?> ♥");$("#body").append('<div id="message" onclick="hideMessages();">Задание выполнено, +<?=$row["for_one"];?><div>');var message = setTimeout("hideMessages()", 2500); <? }else{ $_SESSION['friend_link_id']=""; mysql_query("INSERT INTO tb_ads_views (user,ad_id,ad_type) VALUES ('".$user_row['id']."','".$row['link_id']."','friend')"); ?> $("#body").append('<div id="message" onclick="hideMessages();">Задание не выполнено<div>');var message = setTimeout("hideMessages()", 2500); <? } }else{ ?> $("#body").append('<div id="message" onclick="hideMessages();">Баланс задания исчерпан<div>');var message = setTimeout("hideMessages()", 2500); <? } }}}else{?>$("#body").append('<div id="message" onclick="hideMessages();">Пройдите авторизацию!<div>');var message = setTimeout("hideMessages()", 2500);<?}?>Выбираем с API что мы подписались: if($data["response"][0]["friend_status"]!=0)
Как должно быть: Добавляем в друзья соответственно подписались, сверились подтвердили и получили свои балы, а скрипт не воспринимает действий, если вот так как сейчас, ["friend_status"]!=0 то при подписке не защитывает, если ["friend_status"]!=1 то все будет защитывать, даже если мы не подписывались.
Очень прошу помочь или подтолкнуть куда копать, разбираюсь в php сам и не так уж давно, пожалуйста не кричите.
