<?php @session_start();@error_reporting(7);@ini_set('display_errors', true);@ini_set('html_errors', false);@ini_set('max_execution_time', '300');@set_time_limit(300); define('DATALIFEENGINE', true);define('ENGINE_DIR', dirname(__FILE__).'/..');define('ROOT_DIR', dirname(__FILE__).'/../..'); require_once ENGINE_DIR.'/data/config.php';require_once ENGINE_DIR.'/classes/mysql.php';require_once ENGINE_DIR.'/data/dbconfig.php';require_once ENGINE_DIR.'/modules/functions.php';require_once ENGINE_DIR.'/modules/sitelogin.php';require_once ENGINE_DIR.'/data/config_pkinopoisk.php'; [color=#FF0000][b]if (!$is_logged || !in_array($member_id['user_group'], $conf_pk['group_ap'])) { @header("Content-type: text/html; charset=".$config['charset']); die('Вам не разрешено пользоваться данным модулем!');}[/b][/color] require_once ENGINE_DIR.'/classes/thumb.class.php';define('FOLDER_PREFIX', date("Y-m"));$config['allow_cache'] = "yes"; $news_id = intval($_POST['news_id']);$author = $member_id['name'];$time_s = time();
