<?php $viewer_id = $_GET['viewer_id']; ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////$link = mysql_connect("localhost", "щдщдщ", "щдщдщдщ") or die ("Could not connect : " . mysql_error());mysql_select_db("SB") or die ("Could not select database");mysql_query('set NAMES utf8');/////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// $search_query = "SELECT * FROM marks WHERE uid2='$viewer_id' ORDER BY `date` DESC LIMIT 5";$query = mysql_query($search_query); if(!$query){echo "<p class='text'>Код ошибки:</p>";echo exit(mysql_error());}if (mysql_num_rows($query) > 0){$myrow = mysql_fetch_array($query); do{printf("<meta http-equiv=\"content-type\" content=\"application/xhtml+xml; charset=utf-8\" /> ".$myrow['uid1]." "); }while ($myrow = mysql_fetch_array($query));} else echo "<center><table><tr><td><div style="color:#777777;text-align:center;font-size:13px;padding:100px 0px">Нет такого.</span></td></tr></table></center>";?>
